message d'erreur
tail /var/log/apache2/error.log
hamza
root@debian9:~# tail /var/log/apache2/error.log
[Sun Apr 18 11:42:53.013714 2021] [:error] [pid 2417] [client 192.168.1.42:53946] PHP Warning: md5_file(connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 24
[Sun Apr 18 11:42:53.013797 2021] [:error] [pid 2417] [client 192.168.1.42:53946] PHP Warning: session_name(): session.name cannot be a numeric or empty '' in /var/www/html/index.php on line 24
[Sun Apr 18 11:42:53.015970 2021] [:error] [pid 2417] [client 192.168.1.42:53946] PHP Warning: file_get_contents(connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 83
[Sun Apr 18 11:42:53.016055 2021] [:error] [pid 2417] [client 192.168.1.42:53946] PHP Warning: require(/var/www/html/connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 89
[Sun Apr 18 11:42:53.016072 2021] [:error] [pid 2417] [client 192.168.1.42:53946] PHP Fatal error: require(): Failed opening required 'connect.php' (include_path='.:/usr/share/php') in /var/www/html/index.php on line 89
[Sun Apr 18 11:43:05.102573 2021] [:error] [pid 2418] [client 192.168.1.42:53948] PHP Warning: md5_file(connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 24
[Sun Apr 18 11:43:05.102654 2021] [:error] [pid 2418] [client 192.168.1.42:53948] PHP Warning: session_name(): session.name cannot be a numeric or empty '' in /var/www/html/index.php on line 24
[Sun Apr 18 11:43:05.108163 2021] [:error] [pid 2418] [client 192.168.1.42:53948] PHP Warning: file_get_contents(connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 83
[Sun Apr 18 11:43:05.109004 2021] [:error] [pid 2418] [client 192.168.1.42:53948] PHP Warning: require(/var/www/html/connect.php): failed to open stream: Permission denied in /var/www/html/index.php on line 89
[Sun Apr 18 11:43:05.109044 2021] [:error] [pid 2418] [client 192.168.1.42:53948] PHP Fatal error: require(): Failed opening required 'connect.php' (include_path='.:/usr/share/php') in /var/www/html/index.php on line 89
Vous avez un défaut sur les droits des fichiers reprenez la procédure d'installation.
hamza
j'ai refait l'installation des droits, ça fonctionne (j'accède a l'interface web) mais j'ai l'erreur ci-dessous. est ce que ça peut bloquer le fonctionnement du logiciel Gestsup ?
[Sun Apr 18 15:58:37.836064 2021] [mpm_prefork:notice] [pid 508] AH00169: caught SIGTERM, shutting down
[Sun Apr 18 15:58:53.747543 2021] [mpm_prefork:notice] [pid 503] AH00163: Apache/2.4.25 (Debian) configured -- resuming normal operations
[Sun Apr 18 15:58:53.748106 2021] [core:notice] [pid 503] AH00094: Command line: '/usr/sbin/apache2'
root@debian9:~#
Non
hamza
bonjour,
même après avoir enregistrer mon adresse mail je ne reçois pas de ticket dans le logiciel,
merci pour votre aide.
Pouvez vous déclarer un nouveau sujet et transmettre un impression écran de votre page système.
